regs on earthing SWA | on ElectriciansForums
Discuss regs on earthing SWA in the Australia area at ElectriciansForums.net
J
james king
can any one show me a regulation that the SWA stel outcore has to be earthed. i understand if its to a metal box ect. but plastic?
If you mean the armour, it's normally earthed to provide some protection for the cable (as opposed to one of the inner cores that may supply an earth). The armour can also be used as the earth supply as well.
yes i know it can be used supple a earth. but if the is no need to use the armour as a erath because there is aready a core used for this. what regulation does it come under if its not earth at a plastic box, i have seen lots of these and no amour was earthed
only when metal boxs are used?
The armour is considered to be an exposed conductive part and so must be connected to earth. Also a reg that any buried swa must have it's armour earthed.
Sorry can't find the reference to the ecp.
Reply to regs on earthing SWA in the Australia area at ElectriciansForums.net
All the lamp post cutouts I've ever seen have a twin swa gland plate built in to the base.
loz2754
L
Sounds more positive.
