Just wanted to double check two regs.
1. Do you HAVE TO have a double pole switch between the cut out and the DB (so you can isolate the DB)
2. Do you HAVE TO have a 16mm earthing conductor alongside the 16mm tails (the load on the installation is no more than 5 amps ((teleco cabinet Virgin Media))
