don Logan
Morning,
I'm putting in an extractor hood in my kitchen. The spur that's feeding it is going behind the chimney/duct cover of the hood. This means that the chimney/duct cover has to be removed in order to isolate the supply to the hood. Is this ok, or do need a way of isolating the hood from an accessible place such as another spur above the worktop?
I'd rather not have to put a spur above my worktop due to limited space.
And while i'm here, is there a minimum distance from the hob that the cooker isolator should be? I can manage about 350mm at the moment...
Thanks in advance.
Thanks in advance.
