F
FAA Greenie
Hi guys
Here's one for you, went to a job today where the customer wanted 2x twin socket outlets mounted underneath her permanent mobile home (Yes i know, oxymoron there, but best way to describe it)!! The metal framework either side of the access hatch was the only real option of mounting the two units to be within arms reach of the customer so that was where they went via 4 x 3mm screws drilled through the support frame. However, I did wonder afterwards if there were any regs regarding drilling through girders/metal frames etc for mounting or access seeing as how we have several for wooden joists etc, any ideas?
