1shortcircuit
The main equipotential bonding connection to any gas, water or other service shall be made as near as practicable to the point of entry of that service into the premises. Where there is an insulating section or insert at that point, or there is a meter, the connection shall be made to the consumer's hard metal pipework and before any branch pipework. Where practicable the connection shall be made within 600mm of the meter outlet union or at the point of entry to the building if the meter is external
I'm hoping that by posting this thread that someone with far superior knowledge of the Regulations will be able to help me see through this "Where practicable" part of the reg please.
I have been working with another spark today on a job where a second consumer unit needed to be fitted. During this installation I mentioned that it appeared that we would need to plan our routes for the Gas and Water bonding.
I was a little confused that my point of termination was totally different to the other Spark???
Another council property so all surface mount but a pig of a job to do it my way. The other spark was happy to just run straight to the closest pipe for each service and stated that this was acceptable because it's not financially viable to got to within 600mm because of the disruption involved, time involved and the "reasonably practicable" wording of the reg.
Also, the main earth was way undersized and because it was in the existing Consumer Unit so therefore not an issue?
I would have created an extra days work on top of a very busy schedule but I believe I am right in doing so but the other spark is time served and it's his name going on the Cert's.
I guess what I am asking is, although I think I am correct in believing both Water/Gas and Main Bonding should be replaced regardless of the disruption/extra day involved are there any other regs or valid reasons that would back up the reasoning of the other spark.
Thanks in advance
1SC
