Regulations on cooker wiring | on ElectriciansForums
Discuss Regulations on cooker wiring in the UK Electrical Forum area at ElectriciansForums.net
Bristol
Hi all. I recently moved to a new house and quickly removed the cooker and bought a new one. I bought the Bosch HBA13B150B which is a 2.9kW unit. The old cooker was plugged into a regular 13A socket on the wall behind the cooker. The electrician who fitted the new cooker just plugged it into this socket as well. My problem is that the new cooker is deeper than the old one and doesn't quite fit into the space. The back of the cooker pushes up against the plug in the wall socket. So if I can I'd like to replace the socket with a fused connection unit as this will allow the cooker to sit slightly deeper and will probably be enough to screw it in properly (it only needs another 5mm or so).
The cooker is on it's own circuit, although this is based only on the fact that there is a circuit breaker labelled 'cooker'. There is also an isolation switch above the counter top in the kitchen, which consists of an isolation switch on one side and a socket and switch on the other. The extractor hood is plugged into the socket here, and I believe the larger isolation switch feeds two regular 13A sockets behind the cooker. One of these is for the cooker and the other is for the gas hob igniter.
So would it be acceptable to replace the two sockets behind the cooker with fused connection units? And if so could I use regular FCUs such as this?
get an electrician to put an fcu in and wire it straight into that, don't get the same electrician back though as he should have done this in the first place but probably couldn't be bothered.
Don't see any obvious reason not to fit fcus, is the existing socket flush or surface mounted, if surface you could make space by sinking it into the wall. Check the warranty before you cut the plug off, assuming it came with one.
Oh dear, here we go again :) Daz
Did it actually come with a fitted flex and moulded plug, or has someone fitted their own? At 2.9kW they usually have a termination block. If so and it's on its own circuit why not just fit a CCU and do it properly?
Reply to Regulations on cooker wiring in the UK Electrical Forum area at ElectriciansForums.net
I have replaced the back box for a 35mm one, and it all has refitted more comfortably. I'll get the electrician to check it out when fitting the...
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
