Rehau master programmer change | on ElectriciansForums
Discuss Rehau master programmer change in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Carnforth
hi all, I want to change my rehau programmer to a hive so I can operate it from my phone. I have 4 zones all controlled from a hydronic master and the main rehau master controller. The wiring is low voltage out of the programmer and in to the hydronic master. Is anyone familier with rehau. I bought the house 5 years ago and inherited the UFH and have the upstairs heating and hot water on a hive so it would be nice to add this to it. thanks.
I just want to replace the rehau master programmer with the hive and leave the 3 other rehau room thermostats in place. I'm not bothered if they end up not working, I'll just remove the actuator heads from the manifold so they all come on together. the 4 floors ares are hall, kitchen /diner which is open plan through to the lounge.
Reply to Rehau master programmer change in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Programmable digital cylinder stat I bought one of these: and I am using it to control the temperature of my hot tub, and it works great. Does...
siricosm
