T
timskipper
Hi
I'm interested to know what the relationship is between the two scales on these graphs; AC Watts generated and DV Volts. This is the last two days output from our 20 panel 4kw installation.
Can anyone explain it in plain English? :)
I'm not sure what DV stands for - but presumably this is the DC voltage from the panels. There are two lines so I would assume you have two strings of panels.
The power output (AC Watt) would be the voltage of string 1 multiplied by the current of string 1 plus the voltage of string 2 multiplied by the current of string 2 adjusted for the efficiency of the inverter.
The inverter will adjust the voltage of the panels during the day to maximise the energy produced.
Relationship between AC Watts generated and DV Volts
timskipper,
mdovey,
