Relay coils blowing/shorting | on ElectriciansForums
Discuss Relay coils blowing/shorting in the UK Electrical Forum area at ElectriciansForums.net
hmmmnz
kiwi in edinburgh
Ive got a problem with relay coils shorting out.
24v DC coils, measure 1k ohm
As soon as I apply voltage they short out and put the power supply into protection
System has been working fine, until a detector went into safety and opened the circuit cutting the supply to the relay's coil.
Protection closed but now every relay that gets plugged in, shorts out. 0 ohm across the coil.
I'm struggling to understand.
Any hints appreciated
I was going to say 'check the polarity of the diode' and go back to sleep thinking I had done one final useful thing for the evening when my phome came out of.the time warp it had been stuck in since 10pm and revealed you had already worked this out.
Reply to Relay coils blowing/shorting in the UK Electrical Forum area at ElectriciansForums.net
