Discuss Relay, momentary switch, starter diagram. in the DIY Electrical Advice area at ElectriciansForums.net
Thank you for the advice.Looks about right to me. Ensure that the wire from 85 to the switch is well protected from damage, since, if it shorts to the chassis, it will engage the starter motor.
It's a big relay combined with a hefty solenoid, so it takes a substantial switch to operate it. Such switches exist, but it's normal practice to include a relay and ease the loads on the switch.Just one point, the starter solenoid is basically a big relay in itself, as long as the push button is not a fancy low power thing then why not just engage the solenoid directly from the push button?
This is precisely my intention with the relay, I'm doing a "bare bones " wiring for the motorcycle. Got rid of quite a bit cables, sensors, relays and simplified the wiring as much as possible. My momentary push button most likely qualifies as a fancy low power switch. So I though of including 1 relay for ignition and 1 relay for all the lights.It's a big relay combined with a hefty solenoid, so it takes a substantial switch to operate it. Such switches exist, but it's normal practice to include a relay and ease the loads on the switch.
Reply to Relay, momentary switch, starter diagram. in the DIY Electrical Advice area at ElectriciansForums.net
