Relay wiring for pool switch | on ElectriciansForums
Discuss Relay wiring for pool switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Lincs
Anyone able to throw some light on this,
Have power to the relay, the pulse switch switches the relay, but not getting any power on terminals 1 3 or 5, am I missing something?
[ElectriciansForums.net] Relay wiring for pool switch
Its just a change-over relay. You supply to terminal 3 and take the signal/supply from 1 or 5, depending if you want NO or NC.
Yep, Drawing is limited,
Can only assume it’s not getting power from the input to the relay, and that I have to supply a com to one of the terminals 1/3/5?
Time for a visit from your friendly local Electrician Adam, you know it makes sense.
It's a volt free contact with the look of it.
Turn your multimeter to d.c and check. Make sure you have a correct reference point for voltage detection........... or call a spark either way. ;)
Reply to Relay wiring for pool switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
