relay wiring? | on ElectriciansForums
Discuss relay wiring? in the Commercial Electrical Advice area at ElectriciansForums.net
stevengo
hi everyone. new to the forum and have a question i would like some guidance with please.
i am wanting to switch between 2 ipod docking stations on my multiroom audio system.
i have a relay and base 230vac/30vdc.
i have managed to wire it so it switches manually how i want it to by pushing the button on the relay. so if i push the button ipod 1 comes on and when i release the button ipod 2 comes on. so far so good. i figured that i could use a d.p switch with a feed in from a power supply then a feed out to energise the coil. job done.
problem is i dont know what voltage i should provide to energise the coil as im only switching rca audio which is basically volt free.
can i provide 230v to energise the coil?
sounds like you have a relay with a 30V d.c. coil. if so don't bang 230V across it. it will go bang.
Sounds like you have a 200KV Relay, uncommon but they exist, now, you're going to have to move next to or near a power station, to get a constant 275KV for free, just get some thick alu cable make it off and lassoo it around the first transformer outside of the plant. If you want to do this without being caught you're guna have to kill anyone that sees you.
OR
Buy loads of beefy cable and make your own tranny 230V->200KV, primary 1 turn, secondary 1000 turns might do it.
OR
:17::17::17::17: like me. Wednesday too early to drink? Nah :sunny:
thankyou darkwood and plugs n sparks foe your positive comments. everyone else must be very bored trying to impress one another.
i cant use a two way switch as the relay switches through n/o or n/c contact to go to ipod via the common terminal which goes to the ipod server. because im using volt free contacts i just need to know what voltage is recommended to energise the coil therefore what relay is then required.
the one i have is an 11 pin relay and states 230vac/30vdc. i presumed this was my choice of power to supply the coil. thanks
OR
OR
This is brilliant. Laughed out loud in the office. :blush5: :)
The wiring should e of high quality that maintain the load of all devices importantly in shops where voltage problem arises. At the time of building these shops wiring should be made by considering all the load that is maximum expected.
Not **** Sherlock.....can you run that by me again....!!!!
Reply to relay wiring? in the Commercial Electrical Advice area at ElectriciansForums.net
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
