Remedial Domestic after a Periodoc | on ElectriciansForums
Discuss Remedial Domestic after a Periodoc in the Domestic Electrician Forum area at ElectriciansForums.net
C
claret73
Have been to look at a job this morning that involves remedial work after a Periodic Inspection Report. This has been carried out by another Electrician, whom is Part P Registered.
The observations he has made seem to be non notifiable, as follows:
1/ Wall lights fed off 32A Socket circuit. (These are being disconnected, so nothing required there.)
2/ No Bonding to Water Supply incoming
3/ Blanks required for CU
4/ Certain Sockets require sleeving to CPC
5/ FCU required for Immersion (Not sure on this as I could clearly see an FCU Fitted)
6/ No RCD Protection for lighting circuits (On non protected side of Board)
The House is a rented property and am unsure if there are extra requirements for these observations to be rectified for Landlord Ownership/Tenancy?
There is no additional work to be carried out. Points 2, 4 & 6 are surely not meeting current Regs yet not an Immediate Danger to the current Installation when it was installed to previous Regs. Or as this is a Tenancy Property should all of the above be carried out?
As I did not complete the Periodic, can I carry out the remedial where required? Would there be a requirement to issue a further certificate of satisfactory? If so I couldn't as am not scheme registered.
Thanks for any thoughts on this one.
Personally I would note item 3 as a code 1, as no CU blanks may give access to live parts!.
Item 2 would be a code 2 for me.
Item 4 code 4
Item 6 code 4
You would need to provide some sort of documentation to say that all the applicable remedial work had been carried out be it a letter on headed note paper or an installation certificate with all details in the extent covered section.
As it's a rented property then the letting agency/insurance company will probably want a scheme member's certificate to confirm the install is fit for continued service.
Thanks Lenny
The Property is privately rented, although I'd imagine this would have no bearing on providing any formal written info, be it a new cert or written confirmation.
I'm with you on the Blanks as a code 1. And as for the remainder, although they are non immediate requirements, was unsure, if as it is tenanted these would be needed over a home owner property? Is there anything within Landlord guidelines that place extra requirements on Lettings above 17th & Part P...
Cheers
Hi claret73, could you not issue a MWC and clearly state on it what you have & have not done in the boxes provided?
ie, in model forms of BS7671 MWC Part 1 Descrition of minor works.
and in part 2, 4. Comments on existing installation.
You can always refer to the PIR that was issued.
Regards WA
Cheers
Not really
They have a duty of care,it doesn't even mean a pir is required
They find the pir and some pat testing is the easiest way of convincing themselves, and local authorities, that they are complying with their duty of care
When you examine a lot of those pirs, it makes you wonder who, if anyone, actually does care :rolleyes:
Cheers WA,
However, none of the remedial require notification and wouldn't wish to sign off Part 4 - Declaration as having made it look like I'm taking responsibility for anything outside of the remedial works.
I'm thinking & taking on board Lenny's point of providing a written confirmation that the work I've done noted on the PIR has been carried out to a satisfactory result.
I've been sitting on the fence, thinking about Scheme registration & Part P, maybe I'll follow this up & polish up with the Part P Document, which they didn't go into detail with on my 2330.
Cheers for all the replies, grateful as ever.
Andy
Reply to Remedial Domestic after a Periodoc in the Domestic Electrician Forum area at ElectriciansForums.net
It applies to commercial if it shares the same supply as a dwelling.
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
