remote door entry system | on ElectriciansForums
Discuss remote door entry system in the Australia area at ElectriciansForums.net
yarm
ive got to quote for a door entry/intercom system but ive never done one before, i hear myself saying those fatal words 'how hard can it be?', so, how hard can it be?
Its not difficult, generally a two wire system will be used, good manufactures are:
Airphone and BPT,more cost effective manufactures are videx and fermax.
Consideration should be given to cable length and if a particular cable is required, also is a door release systemrequired.
I used to install and fix door entry systems as part of a previous job
They are easy to wire up but i would wire it up on the kitchen table and get it working there first before fitting in it's final location as is easy to make a mistake and then wonder why as the instruction for some are not the best and easiest to follow as they talk about different ways of installing them with more than one location.
Tim,
Reply to remote door entry system in the Australia area at ElectriciansForums.net
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
so Ze 0.35Ohms and my Part of the Circuit just half of R1+R2 is 0.19353Ohms as its 1.5mm x 10m so well under but dont know of any switch gear...
