Remote light switching / electric door and gate opener on same fob | on ElectriciansForums
Discuss Remote light switching / electric door and gate opener on same fob in the UK Electrical Forum area at ElectriciansForums.net
Dorset
Advice needed please - Got a job where the client wants his garage lights and driveways lights on the same key fob as electric gates and garage door.
Anybody know of a product that would allow a single key fob with 4 switches to operate each of these? 2 of the switches would be at one end of the garden, the other 2 at the other end, so would need to support 2 separate receivers.
I've used Quinetic switches and receivers (TLC) before for lights, which I love (simple and easy to maintain for the client once installed as no batteries in transmitter), but they only have single button fobs
Thanks!
I've used these with 100% success, but they are only 3 channel. I'm sure you can get 4 channel similar.
Thanks!
Can you pair two Quinetic receivers to one switch?
Reply to Remote light switching / electric door and gate opener on same fob in the UK Electrical Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
