Discuss Remote outdoor PIR sensors in the UK Electrical Forum area at ElectriciansForums.net
Steinel IS360 D Motion Detector Black | Light Up UK best ones ive used
Thanks for info......with these sensors can they be so wired that a light switch can override them manually? If so, can all the cables go to the PIR itself. L+N +SW plus sw/L + N to lighthave a look at there website that have most types , they are not the cheapest but are reliable, if its on a flat wall then most area's will be covered by 180 degree one, on corners etc the 200 / 240 ones
usually. most PIRs have a s/l terminal to which you can connect your s/l from switch.
easiest way is to fit a 5A FCU if coming from a non-lighting circuit, then to a switch, a 3core/E to PIR. from PIR to light/s a T/E. i would use black for perm L, brown for S/L.
Reply to Remote outdoor PIR sensors in the UK Electrical Forum area at ElectriciansForums.net
