G
Gmag
Hi all,
I apologise for jumping straight in with a new thread asking questions. I did search and can't find any info on my problem.
Getting to the point...
I have fitted an ABB EXE2S star delta starter to run a 3phase 15kw motor on an extraction fan. The starter is working perfectly but the user wants to be able to remotely switch between star and delta and vice versa after the fan has been initially started.
The end idea is to be able to start the fan normally using the standard push button on the starter but then be able to remotely switch between star and delta via from a pc as and when needed.
My theory was to interrupt the wiring either going into or coming out of the timer for the starter and install and remotely activated relay. This way (in theory) The start button would be pushed as normal and the timer would count down as normal before allowing the delta switchover, although the switch to delta would not happen until the user activated the relay to complete the circuit from the timer coil to the timer contactor.
Also the user 'should' be able to de-activate the relay which would reverse the contacts again and return the motor to star configuration without having to stop the motor and restart it.
I had a quick look at this today and although I understand the star delta circuit wiring I am not 100% on the control circuit side of things.
From what I have researched, the timer should only be triggered when the start button is pushed. Then once the timer has counted down it will activate the timer coil which in turn switches the timer contactor.
When I tested with the multimeter today I found that all 4 wire terminal of the timer showed 230-240v all the time regardless of whether the motor was stopped, in star or in delta.
This seems strange to me so I am obviously missing something.
Is there a simple way I can achieve this using the like of simple relays and pc control? It would be an added bonus to also have the start/stop functions controlled in a similar manor but that isn't needed.
The fan runs in star or delta with no issues.
Thanks in advance.
Gav.
Thanks in advance.
Gav.
