Hello,
I am posting to ask what is the best way to remove some Virgin cables that are clipped to the side of my bungalow, and the associated boxes. These have been there since I bought the bungalow but I don't use Virgin, I have no intention to and I now need it all removed because I am going to renew the rendering. I live in England.
There are two jackets side by side. They come out from a pipe underneath my front garden, then they merge into one where they reach a box fixed to the front of my bungalow that has lost its cover. There, the cabling is connected to another via a screwed connector. The one jacket then splits into two again and both are clipped together along the side of my bungalow, they go round the back and there, they go inside the back room through a hole in the wall. In that room, there are two white boxes side by side, a bigger one and a smaller one. One of the jackets goes into the bigger white box and is then plugged inside a small grey box that is inside that white box. The other jacket goes into the smaller white box, in which four small cables come out of the jacket, two of which go into a connector and two of which have loose ends.
So, can I remove all these cables and boxes myself, or is it an electrician's job, or do I need to call Virgin? Is there anything to pay particular attention to? If I remove everything, there is going to be some loose cabling coming out from underneath my front garden, so how do I cap this?
I tried to post photos but the forum wouldn't let me.
Disconnect the 2 cables at the box at the front of the garden and remove everything that's on the wall and into the house including the boxes.
Virgin only use a single cable now and would most likely replace the cable for a higher quality that they now use on the walls outside.
Remove the box on the front while the render is done then fix it back after.
If you ring Virgin to replace the outside box or remove the cable they'll probably charge, or not even come out to it.
The Virgin street cabinet I'm connected to had it's metal cover stolen along with at least 20 others locally about 18 months ago, Virgin are aware but have done nothing, it's only because my near neighbour keeps wrapping it up with polythene that it doesn't get wrecked.
Will I need to take precautions while doing this? Is there some current going through those cables? Will I be able to disconnect the two cables at the front by pulling or unscrewing them with my hands, or will I need a tool?
Rotherham
removal of Virgin cables
Home Media Centre Forum
Thread Tags
Daniel3103,
mattg4321,
