Remove bolt that is snapped of in brickwork? | Page 2 | on ElectriciansForums
Discuss Remove bolt that is snapped of in brickwork? in the UK Electrical Forum area at ElectriciansForums.net
wales
i was fitting a set of gates and the bolt snapped.
i have tried drilling the bolt in the brickwork but my drill bits are not touching it.
any ideas on how to get this out, if its possible?
thank you
You need to do it as @westward10 and the quality drill bits as @rsgaz and others have advised. You must get a pilot hole in it with a smaller bit then work your way up to the easyout size you need.
Ideally you need to be left with just a shell to weaken the grip that the bolt will have given the amount of torque it will have taken to snap it .
ok the buts i have wern't eve making a scratch
I forget the name of the bits we used on hardened steel , but there are a lot of quality bits available . As has been said , if possible centre punch to give the bit a start , use cutting oil and start with a small bit as I suggested earlier. It went in - it will come out with patience .
I take it this is a quality job and you cannot have an uneven line as @snowhead suggests.
I have seen a electric gate fitter weld a piece of metal on the end of a broken bolt before as the head had snapped off, as the piece of metal was quite long he could use a bit of leverage to turn it anti clockwise and free it up and unscrew it.
That's fine if there is enough to get a weld on to it. Another method is to hammer an oversize nut onto the stud and weld that to it.
Reply to Remove bolt that is snapped of in brickwork? in the UK Electrical Forum area at ElectriciansForums.net
I doubt we would be recommending them if they were not up to the job
