Remove bolt that is snapped of in brickwork? | Page 3 | on ElectriciansForums
Discuss Remove bolt that is snapped of in brickwork? in the UK Electrical Forum area at ElectriciansForums.net
wales
i was fitting a set of gates and the bolt snapped.
i have tried drilling the bolt in the brickwork but my drill bits are not touching it.
any ideas on how to get this out, if its possible?
thank you
[ElectriciansForums.net] Remove bolt that is snapped of in brickwork?
this might come handy .
Core drill around the outside of the bolt if you can't get it out by using HSS drills and a bolt extractor, then use one of those resin bolt kits to fix a stud in to the hole. Ignore baddegg as he doesn't have a sense of humour.........
For anyone not yet sold on cobalt bits, I drilled a hole, through a drill bit! To prove it's not just some picture I found on the interweb, there's my username in the pics...
3.0mm split point HSS-Co bit into 12mm HSS-G...
This would be very impressive,if it was on the flutes.....
You have drilled it,in the soft part.....check if you want,using a file.
This is why you can file the pips and scuffs off,that slipping in a chuck causes.....but you don't use a file,for sharpening the same bit :)
Reply to Remove bolt that is snapped of in brickwork? in the UK Electrical Forum area at ElectriciansForums.net
I doubt we would be recommending them if they were not up to the job
