Removing a switch component from a usb circuit board | on ElectriciansForums
Discuss Removing a switch component from a usb circuit board in the UK Electrical Forum area at ElectriciansForums.net
Edinburgh
Hey guys,
I have a set of lights that are USB powered. They have a push button switch.
I would like to remove the switch component from the circuit board so that when I plug in the lights they come on automatically.
Is this possible/safe to do? If so is it as simple are just soldering off the switch component?
There is a resistor in the circuit board already.
Thanks,
Craig
A photo might help!
If the switch is simply on/off for the USB's 5V to the LED then shorting the switch out with a small length of wire soldered on is going to be simpler than desoldering it.
Reply to Removing a switch component from a usb circuit board in the UK Electrical Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
