Removing Old Cable TV Wires From House Exterior: | on ElectriciansForums
Discuss Removing Old Cable TV Wires From House Exterior: in the UK Electrical Forum area at ElectriciansForums.net
Martina
Brooklyn, NY
I have what I think is old cable TV wires on the exterior of my house. I am hoping that someone from this forum can confirm from these photos that that is what I am looking at. I know for sure that they are not my Verizon Fios wires. Thank you in advance :)
[ElectriciansForums.net] Removing Old Cable TV Wires From House Exterior:
View attachment 59537View attachment 59538
@Martina are you sure that box doesn’t have power. The reason I ask is on the box it says Raychem and the make heat tape to keep pipes from freezing which require power and the cable going up to the roof looks like tieing into the electrical. Hire an electrician to find if it has power or you could go to Lowes or Home Depot and buy a non contact voltage tester and turn it on and hold it next to the wires and if it starts beeping real loud if the wires are live. That tester might be $ 15.00 at most. Another thing I saw was the cables going under your house out of that box possibly going to your water piping
[automerge]1595006214[/automerge]
It appears to be old cable wires or old phone lines but why take a chance
[/QUOTE
Thank you for your post! I’m hoping to take it down because it’s so ugly the way it was installed.
[automerge]1595015967[/automerge]
I will test it to see if there’s power and post back with the outcome. Good advice, thank you!
You are quite welcome and please be safe
Reply to Removing Old Cable TV Wires From House Exterior: in the UK Electrical Forum area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
I have to agree with littlespark stating that the wires should be absolutely cut loose at the fuse or breaker to make it safe. The heaters should...
