Removing someone else's isolation | on ElectriciansForums
Discuss Removing someone else's isolation in the UK Electrical Forum area at ElectriciansForums.net
SJE392
Sittingbourne
Hi all,
After some help here. My boss at the company I work for is adamant that I must remove my electrical isolation, even though I don't deem the work to be safe or complete.
Long and short of it is, if I don't remove it myself, then someone else will.
Is this legal?
Many thanks
Would be good to hear the circumastances. If its a final circuit could you disconnect from the protective device and remove your isolation? If you are simply handing over to someone else could you witness their lockoff?
I think you need to give more context and information.
Fair enough.
I work for a utility company and there was an incident in which a digger ripped a cable out of a duct to a control room taking half the trunking and final circuits with it.
So being an authorised electrician I was sent to make safe and isolate the supply cable. Lock off etc etc.
In the mean time the company responsible for the damage has had their electrician make a temporary repair just to get by. But in my opinion it's unsafe and doesn't comply with 7671.
My company want to get power back on asap and are willing to accept the temporary repair as "good enough"
So my dilemma is I'm being asked to remove my isolation but in my opinion it's not in a good enough state to do so.
Thank you for the further info. What did the manner of this temporary repair entail. Temporary still means compliance for safety as you are obviously well aware.
A cable joint and some lashed up distribution board. Cables hanging in free air that sort of thing.
I would like to know if it's illegal for someone to remove my padlock without my consent
What is coming to mind is section 5 of the Electricity at Work Regulations (free copy here The Electricity at Work Regulations 1989 - HSR25 - https://www.hse.gov.uk/pubns/books/hsr25.htm )
Basically, the duty holder is supposed to ensure that nothing dangerous is put into use.
Obviously, re-energising something after a repair without it being tested does not help the duty-holders case.
You personally have a defence under section 29 that you took (more than) all reasonable precautions to stop this happening.
How will they remove your padlock is there more than one keyholder.
Reply to Removing someone else's isolation in the UK Electrical Forum area at ElectriciansForums.net
Adding a led strip isn't going to make much difference to the 3 phase balance. No real difference to where a 3 phase machine uses one phase to...
Do the occasional job with other self employed sparks but mainly work on my own now and have done for 15 or more years. Given how the employment...
