Render over PVC | on ElectriciansForums
Discuss Render over PVC in the UK Electrical Forum area at ElectriciansForums.net
O
Olec
Hi all, I am currently redoing my kitchen, one of the walls with several 1.5s for the lights was meant to be dot and dabbed. I have capped up straight from the switch and then clipped direct tight around the rsj that is directly above it. On coming home I've found that the builder today has concrete rendered the lot! I've heard about lime chewing through cables but not sure how true this is, do I need to worry?
Reply to Render over PVC in the UK Electrical Forum area at ElectriciansForums.net
