I know it's not electrician specific, but there are enough solar installers on here who also do solar water heating systems, so here's a quick guide I've worked up for the implications of yesterdays 110 page RHI consulation specifically for solar water heating systems.
RHI guide for solar water heating systems
here's the first few bits from it.
RHI for Solar Water Heating systems proposals
Legacy systems (systems installed since 15th July 2009)
In line with the previous plans, all MCS certified solar water heating systems installed since 15th July 2009 should still be eligible for RHI payments once the scheme starts to operate.
How will payments be calculated?
Payments should be based on the original SAP estimates of output from the systems, with no requirement to meter the actual heat output.
What rate will solar water heating payments be made at?
17.3p per kWh of heat generated is the proposed rate to be paid for solar water heating systems.
How long will the payments run for?
7 years is the proposed payment period for solar water heating under RHI.
It's unclear if this is from the start date of the RHI scheme, or the installation date for legacy systems.
