rented property call-out | on ElectriciansForums
Discuss rented property call-out in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
just been called out to a fault. lighting circuit tripping RCD, but only when MCB is closed, so a L-E, i suspect. tenant has just moved in and has had a look at 1 fitting, seen the state of it , then called me. found cables in landing light crumbling insulation, although pvc. same in kitchen light. bare conductors all over the place. no visible main earth. water bond disconnected and just lying there. recent niceic CU change, looks like a monkey's nest. CU jammed hard against DNO board so needs a crowbar to refit the cover. 10mm shower circuit run externally in unprotected T/E. issuing a danger notice.
Reply to rented property call-out in the UK Electrical Forum area at ElectriciansForums.net
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
