It looks like the upstairs in the house has had some electrical work done in the past and I've been left with a couple of blanked off back boxes.
On one of them, the cover plate is loose and looks a little unsightly. While attempting to tighten the screws up, I found the threads on each of the bushing are buggered....
I am going to try to tidy the thread up by retapping with either a M3.5 or M4 tap.
If retapping with the M3.5 does not work, will I need to re drill/clean the holes with say a 3.5mm or 3.6mm drill before trying to run the M4 tap through it or should the M4 tap clean it up ok?
Thanks in advance,
Peter
Thanks in advance,
Peter
