Replace 6AX with 10AX, is that fine? | on ElectriciansForums
Discuss Replace 6AX with 10AX, is that fine? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
gijno
london
Hi, I've a 1 gang 1 way switch 6AX for light in the hallway, I would like to replace with a new one and I've just seen I've bought a 1 gang 1 way 10AX. Is that fine to replace with it or there are any risks?
Plus, the old switch got a L1 for red cable and COM for black cable, the new one has L1 and L, no COM at all. Does the "L" replace the "COM"?
Thanks.
Thanks for your reply. I've tried some search on the net, the common input is usually the red or black cable?
usually red. and the black should have a red sleeve or a bit of red tape on it. so red into L and black into L1. ( lads, this sort of a job is basic DIY, so that's why i'm advising. not many will call out a spark to swap a switch. be nice to have 10 a day of these though. )
Reply to Replace 6AX with 10AX, is that fine? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
Can you do a sketch of the wires and their connections but @littlespark is probably correct.
