Replace ceiling rose with pendant? | on ElectriciansForums
Discuss Replace ceiling rose with pendant? in the Lighting Forum area at ElectriciansForums.net
Essex
Hello
I’m looking to replace my ceiling rose with a pendant light. The ceiling rose has 2 red wires 2 black wires and 2 earth wires (photo attached)
Am I ok to put the wires straight into the pendant connection block(2nd photo attached)
Thank you
  • [ElectriciansForums.net] Replace ceiling rose with pendant?
It may be quite a squeeze to get 2 conductors into those small connectors that come with the new light fitting.
And the bare earth wires need some green/ yellow sleeving over them
you should be able toconnecrtexisting wires intothechoc block.makesit easierif you loosen it fistfrom the earthtag.then reconnect after. note prebious comment asbout the bare earths.
Probably get criticised over this, but those connector blocks come in several different sizes, and I have been known to change the original for one size larger.
I was going to suggest the connectors with 2 push in terminals on one side, and spring hold flex on other
Reply to Replace ceiling rose with pendant? in the Lighting Forum area at ElectriciansForums.net
Any professional forum member in or near Somerset help out? Needs a little more help than we can offer from afar.
well spotted, brilliant reply, a potential reply post of the month there. I didn't spot it at first, but I am old lol
Thanks will give that a try in a little while Cheers Writing to say thank you very much for that advice, its worked! Really appreciate the help
It would normally be the outer terminals where the flex of the pendant drop connect.
