Replace central heating gate valve with 2-port valve plumbing advice | on ElectriciansForums
Discuss Replace central heating gate valve with 2-port valve plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Replace central heating gate valve with 2-port valve My house has a separate central heating loop that heats an annex. The annex loop has 3 x radiators (all with TRV), pump (manually switched) and a gate valve. The gate valve is very awkwardly sited, and difficult to operate, so I am wondering whether it is a good idea to replace this with 2-port zoning valve that is controlled by the pump switch. So pump off = port vv shut, and pump on = port vv open.
Any thoughts gratefully received
Replace central heating gate valve with 2-port valve to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Replace central heating gate valve with 2-port valve plumbing advice in the Plumbers Forums area at ElectriciansForums.net
UFH and zone valves help? Hi all Got an existing combi with 3rd party controls. There is a towel rail zone with 2 port valve and UFH manifold with...
Scott_D
Isolating valve Is it good practice what I'm planning to do. I want to drain the central heating and then put 2 isolating valves on the flow and...
dwalsh1
