Replace My CFL with LED lights? | on ElectriciansForums
Discuss Replace My CFL with LED lights? in the Lighting Forum area at ElectriciansForums.net
GVCCRLM
Northern California
I have two 4 inch recessed CLF 4 pin light cans installed in laundry room since 2012. The bulbs are fluctuating in brightness. I think the Ballast may be failing. I would like to replace with bright 12 watt LED's. Two Options remove or disconnect ballast, or get new cans. I am not a good DIY person so I am confused what is best. Not good feedback for people who have installed LED cans to replace CFL's. I have the Open recessed 4 inch type recessed lights installed. I need bright clear light in this room. Help is appreciated, Thank you.
Whatever you do here it's sound like it's going to be outside the scope of DIY and probably going to be a job for an electrician. Personally I would ditch the two existing fittings entirely and install something more suitable for a laundry room. Problem is the light you have all comes from two downward pointing spot sources so shadows will be a problem. I would consider a surface mount linear LED light option which would give a much more general and diffuse light
Reply to Replace My CFL with LED lights? in the Lighting Forum area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
seen a couple of your posts now and IMO you are trying to save money by doing the design and install yourself even though you have no...
