Replaced light switches not working | on ElectriciansForums
Discuss Replaced light switches not working in the DIY Electrical Advice area at ElectriciansForums.net
Scm00038
Fife
I'm in the process of renovating my hallway and the downstairs has a single light controlled by 4 switches. I've been replacing each switch and testing after each one, however one of them I have changed and now it does not work to turn the light on or off. Other switches still work. All wires fitted into the new switch exactly the same as the old one. Totally stumped - any ideas?
TL;DR
Light switches replaced. Now one switch does not work.
So 4 switches for one light? So two of them would have to be intermediate switches? You didn’t buy double pole switches by mistake?
Both have 4 terminals for wires in the back
Reactions: DPG
Only 1 is an intermediate. Two are two way and two are one way.
I agree with @littlespark if four switches control one light I would expect two intermediates. Can you show the other switches.
Does the outside light work and stay working when you switch the other switches.
Reply to Replaced light switches not working in the DIY Electrical Advice area at ElectriciansForums.net
Often in old wiring, live to the downstairs switch, then in twin (or twin & earth) the two switched lives to the upstairs switch, and a single...
Yes one wire nut will grab a wire but I will suggest an orange one because the wire is 14 gage wire for lighting.
