Replacement battery for emergency grid fitting | on ElectriciansForums
Discuss Replacement battery for emergency grid fitting in the UK Electrical Forum area at ElectriciansForums.net
Can anyone tell me what replacement battery I need for an emergency 4 x 18 watt 600 x 600 cat 2 grid fitting.
My wholesaler is guessing a 3 cell 3.6v - but can't guarantee.
Reply to Replacement battery for emergency grid fitting in the UK Electrical Forum area at ElectriciansForums.net
Depending on the specific battery you (intend to) buy, you might be able to just do Monster alternator -> LiFePo4 battery. The BMS for the fancy...
It should give fairly accurate results. Bear in mind your car will probably have a smart charging system, so worth having a read up on those.
