OliReading
Hi, I've "inherited" a light fitting which I believe used to work okay but then stopped. I've tried swapping the "bulb" (it's not a bulb!) but it's still not working. I'm unfamiliar with the fitting so I'm concerned if I've bought the wrong sort of bulb, which I tried to match with the old one but the terminology is confusing (different manufacturers having different codes and not knowing the compatibility).
Before I assume a wiring problem and call in an electrician (not touching it myself) could anyone confirm for me that the fitting and blub should work together?
The fitting (attached picture) says it takes a "LC-DDE" 28W, and the replacement "bulb" I got is , "GE 28w Wattmiser 2D T5 840 4Pin" as seen on this amazon link: GE 28w Wattmiser 2D T5 840 4Pin: Amazon.co.uk: Lighting - https://www.amazon.co.uk/gp/product/B003YFHVR8
The physical fit is fine, there's no sign of life (no flash or spark when I switched it on). I was hoping to see some sort of plug in "starter" like big florescents but nothing I can see to change.
Would you recommend buying another replacement "bulb" (are they usually reliable?) or anything else I could try before paying an electrician to tell me it's something trivial?
Thanks for your help, great to have this sort of forum otherwise I'd be lost!
Oli
Oli
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
