knnelg
Hi,
I have a (very) old Black & decker circular saw that is still going strong. However the power cable is well past its best and needs replacing.
The current cable is constructed with 2 cores (Looks like 1.5mm) and a combination of hessian string and finer threads all woven together, and wrapped in a PVC sheath of 8mm diameter.
I'm looking for a replacement, but can't seem to find any cable with the above construction. Anyone know of a supplier (to the public)?
Failing that, I'll probably consider a rubber sheathed cable, but cant seem to find a suitably rated one with an 8mm diameter (to go through the cable gland on the saw).
Any help, greatly appreciated.
Regards,
Glenn
Regards,
Glenn
