Replacement capacitor required | on ElectriciansForums
Discuss Replacement capacitor required in the UK Electrical Forum area at ElectriciansForums.net
Somerset
Hi I need to replace a capacitor from a fan but I can't seem to find the exact one online. Would anyone be able to point me in the right direction of where I might be able to get hold of one? Details say cbb60 450vac 50/60hz 40/85/21, please see attached photo.
Many thanks
[ElectriciansForums.net] Replacement capacitor required
Many thanks
eBay has several sellers with that or similar..
https://www.ebay.co.uk/itm/CBB61-Complete-1-8-20uF-AC-450V-2-wire-Terminal-Fan-Motor-Run-Capacitor-UK-Stock/113675490431
The manufacturer says that CBB60 is designed for motor run applications but CBB61 is designed for fan applications. The CBB61 on eBay should do the job.
Agree, wouldn't be my choice but the OP wants to source a direct replacement.
Thank you all for your advice. It probably comes as no surprise that I don't know much about them. Is there something you would recommend that would be more reliable? It's for my extraction fan on my laser machine. The first one the capacitor blew up after about 2 years use. I bought a second fan as was in the middle of a big job but would like to fix the first to have it as a spare, and if there's something more resilient that would increase longevity that would be great
Reply to Replacement capacitor required in the UK Electrical Forum area at ElectriciansForums.net
Yeah, the safety and aesthetics would need to be assessed by the person installing it and my suggestion may not be a practical solution depending...
The white is the neutral. The black is hot to the light, brown is hot to the fan… (or other way round) I did this myself once, but it was in...
