Replacement fan in toilet does it need a certificate? | on ElectriciansForums
Discuss Replacement fan in toilet does it need a certificate? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Striker
Hi all,
I changed a toilet fan about 4 months ago, the fan was faulty so I replaced it like for like, I may be wrong but I thought I did not need to give a certificate under these circumstances as none of the wiring was changed.
The client has just been in touch saying they need one as they are selling the house and the solicitor says it's holding things up.
Your advise please.
Cheers,
Andy
Are you sure the solicitor doesn't want a cert for the whole property? Can't see a fan cert holding up a sale of a property, anyway shouldn't need a cert
Hi all,
Your advise please.
Cheers,
Andy
No cert is required if you only done a like for like replacement.
This is from Part P Building Regs.
Q5: What types of electrical work are 'non-notifiable'?
The following types of work are non-notifiable:
  • Replacing accessories such as socket-outlets, control switches and ceiling roses
  • Replacing the cable for a single circuit only, where damaged, for example, by fire, rodent or impact (1.)
  • Re-fixing or replacing the enclosures of existing installation components (2.)
  • Providing mechanical protection to existing fixed installations (3.)
  • Installing or upgrading main or supplementary equipotential bonding (4.)
  • Work that is not in a kitchen or special location and does not involve a special installation (5.) and consists of:
    • Adding lighting points (light fittings and switches) to an existing circuit (6.)
    • Adding socket-outlets and fused spurs to an existing ring or radial circuit
If part of a bathroom then it may come under special location.
We were told that any alteration no matter how small should warrent a Minor Works Certificate, if you touch a circuit, then it becomes your responsibility and therefore should be tested to verify it is safe, and the best way to document its OK is to issue a minor works.
Its a pain, and usually takes longer than the actual job, but its the best way to cover yourself
Similar to what roukel said we were told by elecsa if in doupt or if anyone askes just do a minor works but no need to register it.
mike.
Reply to Replacement fan in toilet does it need a certificate? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Maybe you could use an in-line mixed flow fan which will be quieter and more efficient than an axial. This one is an S&P which is a good make and...
If this is a genuine change then throw it back at them, a nicely worded email explaining the additional testing requirements and paperwork charge...
