Replacement for Wylex NSB 40 Type 2 ? | on ElectriciansForums
Discuss Replacement for Wylex NSB 40 Type 2 ? in the UK Electrical Forum area at ElectriciansForums.net
hi need to replace a Wylex NSB 40 Type 2 (BS3871) (it has the orange dollie)
will a Wylex NHXb be a straight swap ?
It will fit as they are compatible, makes no difference whether it is 60898 or 3871. The attached picture shows both types.
[ElectriciansForums.net] Replacement for  Wylex NSB 40 Type 2 ?
that pic clears it up, thanks westward 10. The NSB type 2 appears identical to the NSB BSEN60898 in dimensions. The NHXB should fit perfectly as that, according to wylex is the direct replacement for the old NSB range. The circuit in question meets the criteria for a type b MCB and the breaking capacity is 6kA for both existing (Wylex NSB Type 2) and the replacement (NHXB Type B)
Reply to Replacement for Wylex NSB 40 Type 2 ? in the UK Electrical Forum area at ElectriciansForums.net
It's done - I don't know why the RCBO failed but it happens. But can't understand why the live connection is so deep - silly design. But thanks...
