Replacement fuse DU/C GFE 10A 250V (PF) - 10A | on ElectriciansForums
Discuss Replacement fuse DU/C GFE 10A 250V (PF) - 10A in the DIY Electrical Advice area at ElectriciansForums.net
rfinch23
North Yorkshire
Hi
I need to find a suitable replacement for a DU/C GFE 10A 250V (PF) - 10A fuse it needs to be glass fast blow Any advice would be appreciated as I am struggling to find a replacement or where I can get the same one.
Roy
Thank you for the info, I think iy may slightly larger, the manaul has it as the attached.
  • [ElectriciansForums.net] Replacement fuse DU/C GFE 10A 250V (PF) - 10A
Do you have the table of dimensions that go with that drawing (which just shows the tolerances).
ie d1, and in particular "L".
There are only a couple of sizes this is likely to be.
The web page below suggested it is the right size, but since I don't believe everything I see on the interweb, if you've got the dimensions that would help
Reactions: DPG
Sorry, that is all I have to go on, I have been on that site and sent them an email to raise an order request. As of now I have not received a reply.
I have no idea if "Factomart" (labelled a companies holding company) is even a bona fide trading organisation 🤔
My point was the page says the fuse is 5mm x 20mm, so the RS one should fit!
Ok sorry did not put two and two together. Yes in that case I agree it should be ok. Thank you for pointing it out.
Reply to Replacement fuse DU/C GFE 10A 250V (PF) - 10A in the DIY Electrical Advice area at ElectriciansForums.net
For a TN system neutral is deemed at earth potential.
Thank you for the prompt reply, much appreciated. The light fitting is metal and it does encase the connectors yes I will make sure it is...
