Replacement gas boiler | on ElectriciansForums
Discuss Replacement gas boiler in the Australia area at ElectriciansForums.net
O
Octopus
All,
I appreciate that we're in general, not plumbers or heating specialists but does anybody know if there is a regulation that states a replacement boiler MUST be on an outside wall and not use a chimney?
The reason I'm interested is that a mate has been told this and he's not sure if its true!
ta
Thought thats why they produce flue extension kits, so they can be mounted in a location that suit you.
Download the relevant building reg theres a part in there which show all the different locations for boilers flues openings etc
I have extensive experience working for gas firms - so I know a boiler can go almost anywhere!
External wall with a flue straight out, internal wall with flue extensions boxed in then to out side, internal wall with vertical flue through roof, in the loft, in a basement with flue kit, back boiler behind fireplace with condensate pump and flue liner in existing chimney.
As long as you can get a flue out, a condensate to a drain course, and blow-off out if a combi, it can go there.
Reply to Replacement gas boiler in the Australia area at ElectriciansForums.net
This is an RSS feed of thread: Combi Gas Boiler Intermittent Problem - Need to identify replacement part? Content of the thread: Hi All, Combo...
