Replacement inverter & Vat | on ElectriciansForums
Discuss Replacement inverter & Vat in the Green Lounge (Access Only) area at ElectriciansForums.net
from notice 708/6:
Reduced rate applies to ..... solar panels .....
It then defines solar panels as:
[h=2]2.9 Solar panels[/h] Solar panels include all systems that are installed in, or on the site of, a building and that are:
  • solar collectors such as evacuated tube or flat plate systems, together with associated pipework and equipment, such as circulation systems, pump, storage cylinder, control panel and heat exchanger; or
  • photovoltaic (PV) panels with cabling, control panel and AC/DC inverter.
Some might argue you have to install a complete system for the reduced rate to apply, but it does not say that, so personally I would see no problem charging 5% for a replacement inverter.
Reply to Replacement inverter & Vat in the Green Lounge (Access Only) area at ElectriciansForums.net
Thank you! I will add a manual transfer switch. I was hoping that I'd be wrong and it wouldn't be an issue. Sigh. I guess I'll dig out the...
A searh of the manual for the inverter does not return any content for "ground". I do not find any pertinent reference in the table of contents.
