Replacement shower downlighter | on ElectriciansForums
Discuss Replacement shower downlighter in the Electrical Tools and Products area at ElectriciansForums.net
littlespark
Staff member
Supporter
Patron
Solutions
Scottish Borders
Does anyone know of downlight for a shower that fits in a 90mm cutout?
I've been asked by a customer for a replacement. Their current fitting is a 12v halogen, but the bezel has corroded.
All the fittings I've tried are to small a diameter... either 50mm or 68mm.
I need something between 85 and 95 I think...
Go to your wholesalers and ask them mine do an adjustable ring that has the spring arm on a bit you can move about, fits most bigger holes and you can put your suitable light in the middle, here's one I did...cant remember the brand of the ring but it was about ÂŁ20 maybe
[ElectriciansForums.net] Replacement shower downlighter
Hi,
The Aurora Mpro2 has a 85mm cutout. It's an integrated adjustable LED downlight but you can lay the lens flat. IP65 rated, which is uncommon in an adjustable fitting. It also benefits from a five year guarantee. Link below.
AURORA MPRO2
Cheers,
Ivan
Reply to Replacement shower downlighter in the Electrical Tools and Products area at ElectriciansForums.net
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
You too? I thought I was in a unique position:anguished::coldsweat:
