Replacement Switches for Memera 3 Board | on ElectriciansForums
Discuss Replacement Switches for Memera 3 Board in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
London
Good afternoon all
I have a friend whose flat has a Memera 3 consumer board, which has the push-button test MCBs.
One of them does not trip when when the button is pressed, so obviously I wish to replace this for her.
However, it seems to be difficult to get hold of these now. I wonder if anyone knows of compatible replacement switches at all?
Overall the unit is good condition, so she would rather not replace the whole unit as she is retired and has limited income.
Any help would be appreciated, pic attached for reference.
Thanks in advance
[ElectriciansForums.net] Replacement Switches for Memera 3 Board
Only Memera 3 devices can be fitted this includes fuse carriers instead of circuit breakers. They have been out of manufacturer for a long time so any parts you find are likely to be used.
Reply to Replacement Switches for Memera 3 Board in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
You need a wi fi switch that is compatible with your switchbot thermostats. Remove the SCR, use the neutral and live to power the wifi switch, and...
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
