Replacing 3-phase commercial cooker | on ElectriciansForums
Discuss Replacing 3-phase commercial cooker in the DIY Electrical Advice area at ElectriciansForums.net
Wick
Hi
I've removed a 3-phase commercial cooker from my kitchen (combined oven/hotplates/grill). The supply is via a 3 phase mcb (no RCD)
The replacements are a domestic induction hob and an integrated oven/grill.
The hob has 2 line terminals which can be linked for single phase or wired to 2 phases of a 3 phase supply. The oven is single phase.
Can I use the existing 3 phase circuit to supply both appliances - 2 for the hob and the 3rd phase for the oven?
The combined maximum draw for the new appliances is slightly less than the old cooker.
There is a solution to this but I can’t tell you..(electricians code of conduct)
You can use the existing cable btw
Reply to Replacing 3-phase commercial cooker in the DIY Electrical Advice area at ElectriciansForums.net
Given that a lot of EV's only charge from one phase when connected to a 3 phase chargepoint does the customer really need a 3 phase chargepoint...
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
