Replacing a 13A plug fuse with solid brass | Page 5 | on ElectriciansForums
Discuss Replacing a 13A plug fuse with solid brass in the UK Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
London
I read once, never seen one for sale, that there is a solid brass replacement for the standard 13A fuse in a 13A plug. This is to eliminate the fusing in the plug, which is handy when having a heavy appliance plugged in behind itself, like under worktops which are isolated and fused by an FCU.
Anyone know where they are available, if they are?
On a dedicated radial with its own MCB and say a 20A isolator switch a washing machine can have a 15A fuseless round pin socket and plug. That is fine, but many manufacturers say that if you remove the 13A moulded plug the guarantee is void. This would never hold up court if an appliance is connected to regulation being sound and safe, but it is avoiding the hassle factor from these irresponsible makers.
Will you suggest another solution.
A 15A round pin is suitable, but it us the shark makers warrantees that is the problem.
Read back on the thread.
Do you do this sort of thing on other forums as well? I wouldn't mind, but you do seem to have a modicum of electrical knowledge and maybe you could offer something useful?
I always use solid links in my old table lamps which have that nice single insulated twisted flex, 3 amp fuses are rubbish and need replacing far too often when my old stock Chinese 150w bulbs blow, they only last a couple of weeks usually so I reckon I've saved ÂŁÂŁÂŁs in fuses.
You trolling again Dave?
i can help you to save a fortune.
I will sell you as many as you like for your own personal use.
ÂŁ12.50 each with a minimum order quantity of 100.
lead time 14 days.
I think I might be on a winner here!!
Why bother trying to get solid fuse links XD
[ElectriciansForums.net] Replacing a 13A plug fuse with solid brass
A 15A round pin is suitale but it us the shark makers warrantees that is the problem
The most obvious solution that sprang to my apprentice's mind has since been suggested in post #36 - you have a fused spur above, so stick a flex outlet below.
This ain't rocket science and you're seriously overthinking a problem that's very unlikely to occur. How many such 'inaccessible' fuses have you had to replace and what caused those fuses to blow?
Why would you ever need to access such a fuse? if it has blown the appliance is faulty and will need to be pulled out to repair it anyway, at which point the fuse becomes accessible...
Having inaccessible fuses is a no, no. Obvious.
Have fuses accessible like in say an FCU, which is also an isolator as as well.
The thread is about two points:
1)
Where to buy solid links for 13A plugs?
2)
Manufacturers not honouring warrantees because a moulded plug is cut off to hard wire the appliance or fit a round pin fuseless 15A plug.
Define inaccessible and as I have asked on several times which Regulations are you referring to.
Status
Reply to Replacing a 13A plug fuse with solid brass in the UK Electrical Forum area at ElectriciansForums.net
