Replacing a Pull-Switch Lamp | on ElectriciansForums
Discuss Replacing a Pull-Switch Lamp in the UK Electrical Forum area at ElectriciansForums.net
B
BillyBigBalls
Hi guys,
Just been talking to my mum, they have bought a new light fixture(not a pull-switch) to replace a pull-switch light they have in their static holiday caravan. I am a student electrician so am always very cautious when asked by people for help, and I have not seen the lighting myself. I hoped you guys might be kind enough to give me advice.
The current light fixture above a bed, has 2 line conductors twisted together, and 2 neutral conductors twisted together, there is also an earth conductor. The conductors go directly into the pull-switch light fixture. They also think the whole lighting in the caravan is one circuit.
My initial concerns are how the light would be switched, and other lights affected downstream.
What would be the easiest way of wiring this new light?
Much appreciated guys, thanks
Take a cable from the line to a separate switch and back to the locale of the light, use the switched line and the neutral (and the earth) to supply the fitting. If the new light has a 3plate then this is easy if not then you need a junction box in the ceiling (that is accessible).
Reply to Replacing a Pull-Switch Lamp in the UK Electrical Forum area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
