replacing a set of light switches in the stair way with PIR switches | on ElectriciansForums
Discuss replacing a set of light switches in the stair way with PIR switches in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Kaveh
Lodnon
Hi,
Does anyone know i its possible to replace a set of light switches in a stairway that all control the same lights with a set of PIR switches?
The current rocker switches have L1, L2 and COM but the PIR switch I am looging to replace them with only have L1 and L2.
[ElectriciansForums.net] replacing a set of light switches in the stair way with PIR switches
I don't think it can be done this way. Your PIR is a simple one way switch - on or off...
The switch you are replacing is a 2 way... ie, the Com(mon) switches over between L1 and L2
There may be a way of doing this with "Smart" devices.... but employing the services of a local spark will be your best course of action.
This is the same as another recent post concerning stairwell PIR's.
Same street?
what he says ^^^^^. might be possible with some rejigging of wiring. insult a local spark.
You wanting to swap from normal switches to PIRs?
Looking at the new switch it has a limits of maximum switching capacity, how many of what sort of light will they be switching?
Thanks All for your replies, I think I'll get an electrician, thought it be a simple swap out, @Dillb , yes, I want to swap from normal switches to PIRs they'll be switching five 28W D5 fluorescent bulbs.
At work as a simple work around we fitted lights that have an inbuilt PIR sensor in the WCs. We left the original switches in place, although of course they're more or less pointless now.
We didn't even set out to do it that way, we just found a light fitting with the internal PIR when we went out to buy another standard one. It's been a useful upgrade for sure though.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
How much power does the PIR take 24/7? Maybe 3 watts. When only switching a smallish load such as 16 watts there is little saving over leaving the light on for the 8 hour day. That is before taking into account the initial cost and installation charges.
Reply to replacing a set of light switches in the stair way with PIR switches in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
I think your profile pic will scare him away 🤣🤣
