replacing ballast | on ElectriciansForums
Discuss replacing ballast in the UK Electrical Forum area at ElectriciansForums.net
the last time a ballast went, it was a good height to work at and not safe.lol
so im thinking if i remember right, can you take off plastic diffuser/cover from below and drop the connections out without having to be above and take the grey lid off, meaning dropping all the light... which is awkward as hell
The one you have picutered is the type that has the plate I believe, attack it from the top. But these are 4-8 meters high so be careful. If the customer hires a tower scalfold do it, if not walk away. I've got a simlier job comming up and thats the only way I'd do it. ÂŁ200+ per fitting but doesnt like spending money on fitting them saftly???
Reply to replacing ballast in the UK Electrical Forum area at ElectriciansForums.net
Haha! Normally I would sweat just reading those posts! I'm not that steady on my feet when I'm standing on the ground, so ladders are hateful for...
The legs on the bus bar are too long for the new rcbos
