Replacing Comelit 2702 | on ElectriciansForums
Discuss Replacing Comelit 2702 in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
gianmahil
London
Hi I have replaced my old Comlit intercom with a new Comlit 2702. My problem is that the intercom works fine. But the door doesn't open - no noise or anything. What have I done wrong? Wiring for old and new Comlit boards attached. Old one is first new one is second.
Its driving me mad what have I done wrong?
There are also two wires a redand a black one that didnt seem to be connected in the old one and I have left them as is.
HEEELP!
  • [ElectriciansForums.net] Replacing Comelit 2702
Reply to Replacing Comelit 2702 in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I use this one, copy this into a search engine: 200EP Tone Generator Kit High Accuracy Cable Toner Detector Finder Tester with Inductive...
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
