I
itsmrb
Hi all
I was hoping for some advice. I have a dimplex panel heater for the bedroom however the location I want it means that the flax cable isn't long enough to reach the intended socket. I have some spare cable but I've hit a problem. When I tried to remove the current cable I wasn't able to pull it through as there is a little plastic device gripping the cable. In other words where the cable enters the heater, a cable grip is holding in it place. Do I need this or can I just cut below it, remove and old cable and then feed my new in without a grip? Thanks
